91_XLT
- August 1, 2004
- CANADA
- 91 XLT
Hi, I have a 91 Explorer that has around 235,000 KMS on it. I replaced the alternator about a month ago (used one) and everything seemed to be ok. I was on the highway today and was cruising at 100kms/hr when I noticed the tranny seemed like it was slipping, rpm's going up and then would come down again. Before this the engine was idling a little bit rough but not more that usual. I thought it was the cruise control at first, then I shut off the cruise control and pressed the gas manually and still the same thing. When I got off the highway I noticed the engines RPM's were about 200 higher and it was idling around 1000. When I got home and put it in park the rpm's just went even higher to 3000 and stayed there. I turned the motor off and when I went to start it again it cranked over for awhile until the battery died, which maybe took about 15 seconds. I know the battery is not in great shape and the alternator is charging properly because I put a volt meter on it.
Any suggestions ?
Thanx in advance.
Any suggestions ?
Thanx in advance.
