'91 Explorer has 3 digit codes??? | Ford Explorer Forums
rguy
Republic of Texas
'91 Explorer 4x4
I'm in the process of swapping a '94 Explorer automatic transmission in my '91 Explorer that has a 5 speed. I swapped computers and now it idles very bad and triggered the SES light. I peformed the KOEO test and I just need to confirm that the codes have 3 digits. If that is correct, I retrieved 7 digit codes. Can someone verify the '94 computer has 3 digit trouble codes?
Thanks.
Rob
'91 model year should have 2 digit codes. '92 model year (even if built in '91) should have three digit codes. '93 and '94 should put out three digit codes.
I got a little confused: Are we talking about a '91 computer, or did you put a '94 computer into your '91?
Sorry for the confusion. Yes, I put a '94 computer in my '91. However, I think I'd be better off finding a '91 computer from an Explorer with an Automatic transmission than using this '94 computer.
Thanks.
A 94 computer is going to be looking for things like a Cam sensor and EGR which the '91 don't have.
If you know how to tell the difference.. I have a '91 computer in my shed.. I don't know if its from an auto or manual though.. Your welcome to it for the cost of shipping.
I'm "guessing" its from an auto trans since the engine it came with had a flexplate and not a flywheel (I'm not 100% sure they came from the same truck)
~Mark
Did you install the entire '94 engine management system with the computer (sensors, wiring harness, etc.), or are you using the '91 sensors/wiring harness with the '94 computer?-
~Mark
Mark,
this is the number on mine if it helps determine what yours is:
9108 1003
E9AF 14A624 AA
Please let me know what it will cost to ship the computer to 75703.
Thanks.
Rob
If USPS priority mail is fast enough Its < $9 (I think its $8.60).. I already have USPS priority mail flat rate boxes here for the t-shirts. If you need it really fast I could send it from work (Fed-Ex)...
I'll bring it into work with me tomorrow and see if I can figure out if its auto or manual.
~Mark
the numbers on the gray plastic are the following
9021 1002
E9AF 14A624 AA
The numbers on the white sticker are...
A0Z1
EEC-IV
CSKT NPF 0F061
*9K4AR1107NPY*
EFI-MA35g F07F-12A650-ABB
Does anyone know if this computer is from an auto or manual trans truck?
~Mark
I got this from car-part.com when I told it I wanted an ECU for a 91 explorer..
Elec Cont Unit (ECU), (R kick panel), AT, Fed, ID F07F-ZA
Elec Cont Unit (ECU), (R kick panel), MT, Calif
Elec Cont Unit (ECU), (R kick panel), MT, Fed
Elec Cont Unit (ECU), (R kick panel), AT, Calif, ID F07F-ACB
Elec Cont Unit (ECU), (R kick panel), AT, Calif, ID F17F-XA
Elec Cont Unit (ECU), (R kick panel), AT, Fed, ID F07F-ABB
Elec Cont Unit (ECU), (R kick panel), AT, Fed, ID F17F-ZA
Elec Cont Unit (ECU), (R kick panel), AT, Calif, ID F07F-AAA
Elec Cont Unit (ECU), (R kick panel), AT, Calif, ID F17F-VA
Elec Cont Unit (ECU), (R kick panel), AT, Fed, ID F17F-YA
According to that, what I have is from a Federal Automatic transmission vehicle.
Let me know if you want it.. I can get it to USPS tomorrow if you like (You would have in Saturday or Monday).. If you need it really fast I'll fed-ex it from work (would cost more than the $8.60 but would be < $15).
Just let me know.. (I'll bring it/box to work just in case you don't answer until I'm at work).
~Mark
~Mark
Awesome!!! UPSP is fine. Just give me your email and I'll send you the funds via Paypal.
Thanks a bunch!
Rob
Its all boxed up.. and ready to go..
USPS flate rate box is $8.95 (the envelope is $4.60.. I got the pennies confused between the two)..
My email is <removed>
don't forget to give me the address to send it to..
~Mark
My email is "<removed>"
~Mark
You should have the money now.
I'll let ya know how it works out.
Thanks a lot.
Rob
Elvis has left the building...
The Postal Carrier.. (I can't call her a mailman) picked it up from work today..
I sent you an email with the confirmation # I received from USPS.
~Mark
I see it got delivered over the weekend.. did you try it yet? is everything hunky dory(sp?)?
~Mark
~Mark
Not yet. I'm checking it for viruses. :)
Seriously though, I've just been too busy, but I think I'll have time tomorrow.
Thanks again and I'll let you know how it works.
Rob
~Mark
I just completed the swap today and test drove it. So far so good. I was a big job but turned out nicely.
Thank you for the computer and I appreciate all the information I've gathered from this board, not just this thread.
I just noticed that the SES light was on. Now it's triggering codes 22, 67, and 89 (Map sensor, lever, and converter clutch circuit failure). what up witdat?
