'91 explorer lift help needed | Ford Explorer Forums
SCRAPMETAL
Red Hill, Pennsylvania
'91 xlt
I have purchased a 3" body lift for my '91 4dr XLT and was wondering if there is anything else I can do to get extra lift without buying an actual suspension lift, I will buy a susp. lift when the money is readily available, but for a few years it won't be any comments will be appreciated. I was thinking of spacers in front and add-a-leafs in the rear. I was told I can get an extra 2 inches by doing this?
thanks,
John
you can post on here or email me directly at ezalbynnhoj1@comcast.net
thanks again !!!!!!!
The coil spring spacers and shakle & add-a-leaf in the rear is a cheap lift that will give you about 2" of lift, if you watch the forum closely sometimes you can get a used lift cheap.
thanks for the info should I use shackles and the add a leaf or just one or the other....I need a book "Lifting for dummies" I believe '96 F150 2wd coil spacers will do the trick up front. and warrior shackles in the rear but that will leave me a little short of 5"s of lift I'm looking for (including 3' body) ....am I right?? So thats where the add a leaf comes in.what leafs do you recomend ?
John
I used explorer pro-comp, I ordered them from summit
