ev_dude
- September 29, 2003
- Fairbanks, Alaska
- '91 XLT
hey guys this is my 1st post, seems like a great fourm . i have a problem with my 91 explorer, the dash lights do not work. my insturment gauge lights are out, as well as the lights inside of the heater/ac panel (i have an aftermarket CD deck which works). i have checked ALL of the fuses and the "instrument panel illumination" fuse was blown. i replaced it and it just blew again once i turned the headlights on. i eventually got around to checking the headlight switch which was acting funny earlier, it would make a grinding type noise when i turned it (the dimmer) i looked at it and sure enough the spring coil was seperated from the other end of the coil on the switch. it looked like it had been soldered in half. i later replaced the light switch only to have the same thing happen again,the fuse blew, and once i replaced the fuse and adjusted the dimmer, the spring coil got soldered in half again....i now have another headlight switch and am lookin for some help before i blow this one too, i would appreciate any help you guys could give me. the winters in alaska are pretty dark and it would be nice to know how fast im going at night & how much gas i have left
thanks
evan nielson
evan nielson
