2000 explorer no dash lights | Ford Explorer Forums - Serious Explorations
Jay Mann
INDIANA
2000 explorer Eddie Bauer
Does anyone know which wire supplies power to the dash lights on the back of the instrument cluster. That way I can trace it back to see where I'm losing power.
See the bottom of the attached diagram. You have power going in on C287 pin 4 then out on C287 pin 7, and the other bank of lights are power in on C286 pin 8 and out on C286 pin 7.
Next if you look up at the connector listings toward the left side of the diagram:
C287-4 = Red/Black wire (which connects to same color wire C286-8). Power.
C287-7 = Black wire (which connects to same color wire C286-7) Ground.
"Power" above comes from the interior lights circuit. You can find that and associated diagrams linked in my sig below. Ground, just check resistance to any chassis ground (most unpainted bare metal areas).
  • instrument-cluster-instrument-cluster-circuit-1-of-2.pdf
