DryDog
- February 14, 2004
- Woodbury, MN
- '91 XL
It sounds like someone beating on an aluminum pot with a wrench.
Last winter the waterpump gasket started leaking. It was 5 degrees. I let it drain and figured I'd fix it in the Spring. A couple months later I had to move it and it had a noticable knock but not bad. I last started it in May and it was a very loud knock. A bit hard to start and the noise was in sync with the RPMs. I heard it on the right head area but didn't let it run long out of shear fear.
I was just following a search for "knock", someone suggested bad gas. Could it be that simple???
Matt
Matt
