91 X Front Diff Yoke Removal - HELP | Ford Explorer Forums
91-Exploder
Concord, NH
91 + 96 XLT
While attempting to drop the front driveshaft for maintenance one of the yoke bolts decided it was time to seize 'n snap all were pretty crusty so this one did not 'feel' wrong.
In order to safely remove the yoke so I can drill and retap the hole on ye old drill press. I assume that I just need to remove the pinion nut and then use a bolt type puller to remove the front half of the yoke.
Once this is complete I assume that I drive the yoke back on with the pinion nut.
Service data does not clearly elucidate this process.
