2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Battery voltage?
I assume that your engine is the 1996 OHV V6 and that you have the automatic transmission.
Have you measured the battery voltage with the ignition off? It should be at least 12.6 volts.
Have you tried to start the engine with the shift selector in neutral instead of Park?
You may want to check Fuse 1 (60 amps) in the Power Distribution Box. Also check Fuse 24 (10 amps) in the Interior Fuse Panel.
Does your Theft light illuminate slowly when Ignition is Off and rapidly when the Ignition switch is in Run or Start?
