92 Explorer Starting Problems | Ford Explorer Forums
rjginca
CA
92 Explorer
Truck won't start with key.
everything works when key is in on position. when key further turned to start position - Nothing. If I leave key in start position, remove red/lt blue wire from starter solenoid tererminal and jumper from positive battery post to this same solenoid terminal - WALA truck starts.
What do I check next?
check the wires to the starter
your starter relay has bit the farm. Its located on the passenger side of the engine comparment.
Replace it and problem solved.
i agree i thought you were talking about something else
