gforceman
- April 7, 2003
- Virginia beach VA
- 2003 limited 4.6 V8
ok , i read through alot of posts here retaining to RABS .. but when i lifted the rear end off the ground the drivers rear doesnt work at all and the pass works very little if any , the last time i bled the rears i can only bleed if the key is in the ON position or motor running , key off they wont bleed , i was thinking the rear wheel cylenders are stuck or frozen , im not getting enough braking power to the front wheels , new pads , hoses and rotors and bled , i know the last owner replaced the rabs modual with one from a junkyard cause of an abs light im not getting a light now , just no braking to rear wheels,, any thoughts thanks !!
