yosh18981898
- October 17, 2003
- Chana IL
- 92 sport 4x4
So the other day I jump in my x to head to town and all of a sudden the transmission was grinding every time I downshifted from 5th to 4th. It would grind as I was going into 4th. Every other shift, including 3-4, 4-3, 4-5, and 5-3, is smooth as silk and the transmission makes no unusual noises. It did this on every 5-4 shift for that trip. At the end of the trip I sat in my driveway, with the engine running and clutch in, and shifted 4-5 and 5-4 repeatedly. Since then, the 5-4 shift is just as smooth as ever, not grinding at all.
I like to fix issues before they become real problems, and in this case, at 113,000, my tranny is just too young to die. Because of the nature of the problem, I'm thinking it has to be a syncro (although I've never been inside a manual trans, so don't hesitate to correct me). My first action will be to drain the trans fluid and refill it. I'm thinking since the fluid in there is 13 years old, there could be gummy fluid and metal shavings that are getting the syncro stuck and keeping the gears from alligning as they should. (Again, if this doesn't make sense, then tell me!
I want to put synthetic fluid in there next time. Does anyone have recomendations? Also, I was planning on removing the shifter and floor access panel to gain access to the fill plug, will this work? Also, while I'm in there, I may as well replace those rubber shift rail plugs with the metal one's I've heard guys raving about. I need information on where to get them.
Thanks guys!
Thanks guys!
