93 Explorer 4x4 | Ford Explorer Forums
93 Explorer 4x4
DoubleDD1
sterling hgts michigan
93xlt
truck wont shift to drive unless you let off gas 1&2 ok they say maybe sinoid in trans
somebody please help anserwer
sombody please help
I'm not too good with tranny's or I'd help ya. The only thing I can think of is maybe shifter solenoid is on its way out maybe. Or maybe your soon due for a new tranny or tranny rebuild. Just a tip next time you have a question regarding a tranny/4X4 what not see if there is a specific area for it to be posted. Goodluck with your transmission. Give it a little time yet someone will eventually be able to answer your question. Have you tried a search?
I probably can't help much, but I will ask for clarification, so that someone who really knows can help: It starts out fine in 1st gear, shifts into 2nd gear just fine, and then won't upshift into 3rd, is that right? It's important to know on an A4LD, because you only have two solenoids: one to control the 3-4 shift and one to control the torque converter lockup clutch (TCC). If you have a problem with the 2-3 shift, it isn't a solenoid problem.
Maybe a problem in the vacuum modulator, though I would expect a problem with the vacuum modulator to also effect the 1-2 shift. Or a problem in the valve body (sticky valve or something) or a broken band or something.
