KobeJ05
- March 8, 2009
- Marina, CA
- 1994 explorer 157k miles
hi the codes came up in this order 72, 17 and 31. any ideas what i can look into? i replaced the o2 sensor. i disconnected the battery when replacing it. truck ran good for an hour on my route job after putting in the o2 sensors but the light came back on and went back to the way it was running and still comming up with the same codes.
72 insufficient manifold absolute pressure (MAP) change during dynamic response test
17 cfi fuel control system fault or rich/lean condition indicated
31 egr positioner sensor below minimum voltage
other question is does my 93 explorer have a map sensor i just had a used motor from a 94 ranger put in it. if so where would the map sensor be? thanks
