MillerAPF97XLT
- January 2, 2016
- Branson, MO
- 1997 Explorer XLT
Working on a friend's truck, scanned it the other night and pulled a KOEO code 157 (also got a 565, I think, for canister purge failure). Truck has a VERY new 4-wire MAF sensor (a Motorcraft, even), installed by the last mechanic under the hood before me. Owner complains of rough running and engine not wanting to wind past 3,000-3,200 RPM. Would help to know what the PCM wants for reference and signal voltages to and from the MAF. Got a multimeter and backprobes, just need the numbers and wire functions. I'm kinda hoping either for a bad-out-of-the-box MAF, a crummy connection or bad wiring between MAF and PCM, in no particular order. As for the 565, the purge valve and purge hose elbow look original, with plenty of weather-checking on the elbow. Owner said he thought he might have stuff to replace the elbow with at home. Could the purge valve be stuck open, so the engine is running with some of the air un-metered? This one is going to be a bit of a challenge, since the owner still drives it and it's not sitting in my driveway... Any/all input/advice is greatly appreciated. Thanks in advance - Chris
Edit - Also, could the IAC be stuck open, again allowing the engine to run on un-metered air and decreasing the signal voltage from the MAF?
