PtownBubba
- January 16, 2015
- 1993 Ford Ranger
Seems a common Ranger issue,,, wipers work only work on high, and when turned off they do not cycle through and rest correctly. This 93 Splash does all that,,,, replaced steering column multi-switch,,,, have new motor assembly,,,, did not install it, but connected it ,,,,it works the same as one in truck,,, high only,,,,, No relays in electric dist. box next to battery,,, no relay on steering column,, or nearby,,,,,,,,,,, ???? where is a relay or control module for a 93 Splash ??????
