93 trans shift problem | Ford Explorer Forums - Serious Explorations
catvcableman2009
jackson tn
I have a 93 ford explorer. Takes forever to shift into drive or any forward gears. Reverse works fine. After it goes into gear the trans shifts fine going down the road. I have check and changed fluid and trans filter so no shavings in the trans pan. When you pull the vac line off the trans modulator, gears shift all fine. No trans fluid in the vac line. I wanted to check with the board before i go out and spend $70 on a new modulator for it... Help!!!!
