94 2wd explorer vs 94 2wd ranger | Ford Explorer Forums
Navajo94
chandler, AZ
94 Mazda Navajo
I have asked a few times and never received an answer. I thought the pieces were the same but I see several companies marketing different lifts for each. As well as selling 2wd ranger lifts with no reference to the explorer. Someone has to know the difference or if there is none. It will be much easier building a desert truck with the available ranger parts.
There is definitely a difference in the 2wd Rangers and Explorers. 4wd's are the same. 2wd and 4wd Explorers share the same frame whereas Rangers have different frames for 2wd and 4wd. Explorers aren't necessarily more expensive to build, only the beams will be different. You could buy some bent beams from Autofab and everything else is the same....
