94-95 head swap | Ford Explorer Forums - Serious Explorations
94-95 head swap
BIG600CAT
CARLISLE PA
ive got a 94 4.0 that has cracked heads. they cracked between the valves on the first cyl on both sides. i have a 95 4.0 and am womdering what all i have to bring from the 95 to the 94 to make the swap work. thanks
yes the heads (91-94:93TM) will bolt right on. When you bolt them on (95-97: 95TM) you will raise the compression to around 10:1 and will have to use premium gas
so If i do a mild port on some 95 heads (4.0 sohc) they'll bolt right on and raise the comp?
hmmmmmmmmmmmmmmmmmmmmmm...:)
95s came with ohvs
ok so i dont have to worry about intakes or injectors cool
