94 Explorer Limited A4LD Tranny leaking | Ford Explorer Forums
savvy5473
1994 Limited
Hi,
My transmission is leaking from the shift linkage hole. I am assuming the seal inside is not seated properly as the transmission has been rebuilt not too long ago. Does anyone know if this is easily replaced just by pulling the pan and removing the shift linkage or will I have to remove the valve body too in order to pull the shift arm?
Thanks,
Shane
