jwb28207
- July 27, 2013
- Chesterfield, Va
- 1994 Ford Explorer 4.0
I'll try to be as detailed as possible due to desperation
I have a 94 explorer 4.0 with 141,000 miles that is my daily driver since last July.
Lately I've been noticing the idle started to seem like there was a miss and it started to get worse over a few days, so I simply did a tune up of filters, plugs, wires, coil, and added fuel treatment since it hadn't been done since i purchased the truck.
Seemed to work well for a few weeks and then I noticed worse and worse fuel mileage accompanied by a large decrease in power. Also there was really bad spark knock under heavy accelleration which I controlled with higher octane gas so far.
slowly the problem has been getting worse and worse to the point where The truck would cut off at idle and surge at high speeds. Then a few days ago the engine would start then shut off.
I have tried a few things to fix the problem including:
-Upper and lower intake gaskets and torqued bolts
-All new vacuum lines
-Canister purge solenoid (old one broke when pulling out vaccuum lines.)
-Cleaned MAF sensor and IAC as well as all other connections.
-ECT was replaced
-Relays for Fuel Pump and EEC
-Also fixed a hole in the intake hose
Truck ran like new for about 10 miles. cut it off and let it sit and now it is back to where it was before, except the spark knock is back.
The throttle body does not have a gasket right now due to being on back order.
Also I used an Actron OBD1 scanner
Continuous memory codes:
-172-Heated O2 sensor, lean condition, right side
-214-Cylinder Identification Circuit Failure
-332-EGR Valve opening not detected.
KOEO codes:
-335-EGR Sensor voltage out of range.
Fuel pressure @ 38 w/ vaccuum, 45 w/o vaccuum. Pressure stayed after 5 min.
Any and all input is highly appreciated. I have no other transportation at the time so if I missed anything please shoot a reply.
Thank you
-ECT was replaced
KOEO codes:
Thank you
