sampexp
- March 18, 2002
- TX
- 94 Eddie Baur
Hi
I own a 94 Eddie Baur 2WD. Has 89K on it. The maintenance on this is done regularly. Recently I noticed the transmission hard to shift to the first, and when I checked, the fluid level was low. Now, I had changed the Trans. fluid/Filter/Gasket not too long ago on this. I checked EVERYWHERE possible but could not find a leak
1. Checked the pan/gasket for leaks
2. Checked the seals for leaks or splatters
3. Checked the Return lines to the radiator
4. Checked the coolant quality to see if it leaks inside the radiator
None of these worked. I simply cannot find a leak.
Two important things though:
I have always used MOBIL1 synthetic Motor oil and ATF. A guy at O'Rielly told be that MOBIL1 ATF is known to burn fast. Now, my transmission oil looks a little dark in color than what it should be although I changed it recently. Any ideas about this ?
Is my tarnasmission going bad ?
Anyway, as soon as I fill more transmission fluid, I have no shifting problems. This, to me, leaves out a problem with the transmission/clutch too.
Please help ?
Thanks
Please help ?
Thanks
