('94 Sport) Trunk Lock Stuck? | Ford Explorer Forums
TM21fourT3
Connecticut
'94 Explorer Sport
Here's the issue:
I hit the unlock button inside my drivers door today and the passenger unlocked, but the trunk did not. So I then went to the back and tried to use my key instead, the key also did not make it open.....
What is the problem?
Please, I need some help with this issue....
Did you try to crawl through the back seat to unlock it manually? I think once you do that you can open the hatch and diagnose the problem more thoroughly. Sounds like it might be a bad wire. I know by using the button to unlock it more than using the key tends to let the tumblers inside seize up from corrosion. Try spraying some PB-blaster inside the key hole and see if that frees it up some.
Thanks man, I'll give that all a try today. Any other suggestions though?
