95 Exp. Front Wheel Bearing Replacement | Ford Explorer Forums
AustinTX
Austin, Texas
1995 Explorer
I recently tried to replace brake rotors on my explorer. After repacking the bearings I have been experiencing a grinding sound when breaking. I have tried losening tightening and everything between to eliminate the sound. I took special care to get the bearings seated and greased properly. Is there some trick that I am missing? Has anyone else experienced the problem? Potential solutions?
how did you repack the front bearings on a 95?! they are a sealed unit and not repackable.....
or is it a 4x2?
4*2
It is a 4X2. The bearing is new, but grease packed
ah... ok.... anyways... still a grinding sound.... is it a bearing sound or brakes? many times we did brakes where i used to work and the customers wanted cheap pads... the pads were what gave them a grinding noise... not the bearigns
Yup...not the pads
After I did the repair and took it on the test drive worked fine for the first 5-10 stops. As I was returning the grinding sound started and I have not been able to get rid of it since. I wish it were the pads (or even warped rotors for that matter, but not so luck!).
You torqued it properly? tighten, loosen, tighten? Might be some crap got inside the grease?
most problems with people doing their own bearings, is they over tighten.
-Drew
Torqued to spec.
Torquing is the most likley problem that I can think of but I have played with it so much tighten, loosen, and then tighteded that I feel like I have tried everything in between. I suppose I should get out the torque wrench, find the specifications, and then follow them. Thanks
are the calipers on correctly.???
I'm pretty sure you overtightened them, if you didn't use a torque wrench. heh
