gungeek
- August 9, 2007
- Hagerstown, MD.
- 95 Ranger
My girlfriends 2.3 ranger - range of symptoms/signs. Yes I've read up on boards
The other day she calls says truck is bucking and o/d light flashing running hot. I tell her to pull over turn it off wait a few seconds start it again go back to work and call me if it's still screwy. She does that, better but still hotter than usual.
At this point I find your forum, and start reading up. I am a longtime mechanic and have only ever rebuilt a TH350.
Next morning she takes it to a local shop for a fluid/filter change and sure enough the crap shifts improve, and it no longer needs to be floored to shift from 4 to 3 on light hills. She goes to work, fault does not repeat but she says it still runs hot..."all the way up to the middle" I tell her I,ve never owned a vehicle that did'nt average at the middle of the guage, she thinks the sky is falling, and blames me for the problem because I usually shift into D while the truck has not completly ceased all rearward motion. 300+K on the truck 170K on the junkyard tranny in it.........My fault...makes me smile in wonder.
Next day we drive from Hagerstown, MD to Frederick, 40 mile trip with a mountain in the middle, temp guage that never runs past 1/4 gets to 1/2 on top of mountain and other hills. Later in the day after 100+miles and a fast trip on a windy back road the fault repeats for me finally...obviously a limp mode situation, reset, go home.
Codes wrought this morning,
P1751, shift solenoid A performance
P0731, gear 1 incorrect ratio
P1131, & P0131B, upstream O2 that was not humanly possible to plug back in after replacing the converter, so I new it would have an O2 code.
P0102, Mass air flow circuit low.
Also the truck has been shuddering considerably at stop in drive for a while.
My take on this is the TC has probably been out of balance for a while, hence the shake, and now is running hot enough to boost coolant temps.
I am assuming I am going to have to R&R&R this trans.
The good news is my best buddy since 2nd grade 36 years ago works at a ford dealer and can probably get the guy with all the experience on these to reman it for a few hundred bucks.
What do you more experienced guys think??? fix it in, or fix it out??
Thanks for the read.
Barry
Barry
