marragtop
- April 14, 2001
- balt, md
- 91, 92, 95, and 2000 xlts
I have a 95 XLT 4x4 with 195k on it. I suspect the drive train is all original. I have a 'chirping' noise when the truck is moving. It does it in and out of neutral. I jacked the rear up and put it in drive and the chirp is still there, so I assume it's rear wheel or drive shaft related (not front wheel related). I don't see any grease fittings on the Ujoints.... is this correct? Also, there is no fluid/grease on the rear backing plates, so I assume my rear axle seals are good. Also, it has disc rear brakes.
Does anyone have any ideas how to better isolate the problem?
