gluciano
- May 13, 2009
- Fort Lauderdale FL
- 95 Splorer XLT 2 WD 4L
Hello everyone. The other day I traded my friend a HP laptop for a 95 XLT with 124k miles on it. The truck body and inside is in great shape, the engine needs a water pump which I tried doing but couldn't get the fan off. I have to get a strap wrench to hold the WP pulley.
None of the dome/map lights come on when the doors are opened as well as none of the door lights. The rear dome/map comes on when you turn them on at the switch on the actual lights on the headliner. The fronts do not work as well as the compass will not turn on even when you press the button on the console of the lights. I checked all of the fuses and they are all fine and not broken.
This is on a 4.0L
Thanks a lot!
This is on a 4.0L
Thanks a lot!
