justanother1
- April 7, 2004
- Dover, PA
- 96 XLT; 97 XLT
Been searching for a knocking (only heard at idle - 1200rpm) and found the flexplate is loose on our 96 4.0L ohv. I found this by checking the to see if the torque converter nuts were loose through the starter hole. Should I replace the flexplate and the crank spacer? Would you buy these from Ford or the local parts store? I will definately be replacing the bolts. I have not pulled the tranny yet because I found this last night. I would like to have the parts before pulling the tranny.
