96 Eddie bauer 4.0 fuel rail | Ford Explorer Forums
Aphillips2525
1996 Ford Explorer Eddie
Ok so the shop told me the intake manifold gaskets needed to be done so I went and changed them, problem is that you have to take apart the whole dam engine to get to it. So I pulled it all apart all the way past the fuel rail and all the injectors. I noticed a couple of the o rings were bad so I changed all of them and I put the fuel rail back on, bolted everything back down and tried to start it back up. Well now it won't even start, the fuel rail has no pressure and when I go to start it, it revs up real high then back fires, sputters and dies. I pushed the release pin on the rail and I got a tiny bit of gas out of it and that's it. Seems like there is no pressure now in the rail. Anyone have any ideas?
