96 Exp - automatic entry - how is it supposed to work ? | Ford Explorer Forums
grade_t
1996 Explorer Eddie Bauer
1996 Explorer Eddie Bauer version, stock condition. Just bought it used and very happy so far (considering what I paid ! ). This vehicle has some minor issues !
This vehicle did come with a remote keyfob, which appears to work, at least somewhat. Follow me here and you'll see what Im doing:
My current start sequence:
1. use keyfob unlock button 2x to gain access to driver's side rear door. Driver's side door exterior latch is physically broken so this is unfortunately necessary. Open driver's side door from inside, by doing a very long reach. Fortunately I have long arms: this is awkward but doable.
2. sit and put key in ignition (turning it over at this point wont work, but I feel it should).
3. tap and hold on U part of passenger side door lock (U / L ) switch until "chirp" is heard from engine compartment, and visual cues from dash also occur. Engine will now start normally. Yes, bizarre.
Obviously, Ford Explorer buyers would not have to reach over to any control on the passenger side area in order to control and start the vehicle, so something is seriously amiss with my workflow. Not sure what though.
The keyless entry pad does work to unlock the doors, but once you gain physical access, the problem of getting the "chirp" (whatever that means) remains.
Any insight would be most appreciated !
its obviously an issue in the antitheft module
when you force the unlock on the passengers side you are disarming the module
there's obviously damage in the drivers door and maybe the whole front end, I would start looking for crash damage
there's no crash damage at all, but a good guess.a
- where's the theft module located ?
at what point should the chirp be heard on a normally functioning 96 Explorer, if at all ?
thanks for any / all assistance
I dont get a chirp on unlock... you know this might be an aftermarket alarm or starter system causeing a bad interaction
