Jim_WY
- February 11, 2010
- Wyoming
- '96 XLT, 91
Hi. I've read a lot of threads on here, and got a lot of ideas to try with this problem, but so far, no go.
I've got a '96 explorer with the "premium" audio package. AM/FM-Cassette head with a CD changer in the center console. A while back, the audio became intermittent and finally died completely.
Not knowing anything about it, and wanting a new head anyhow because I wanted to have MP3 playing and have little use for CDs or cassette these days, I bought a very cheap "Dual" unit from Wally World for about $40 that has no mechanical drives at all, fairly low power, but has AM/FM, and a USB connector as well as an SD card slot and a "line level" input on the front. Just what I wanted and nothing more.
Anyhow, I connected it up, and nothing. So I figure there's a separate power amp somewhere in the car that's the real culprit. That got me searching on here, and I've read a lot.
So far, I've tried connecting the wire from the new head that puts switched +12 out to run a power antenna or turn on an external amp to the "blue" and even the "blue white" wires in the car's harness to see if that would power up the (presumed) external amp. Nothing.
I tried putting the original head back in and pressing the 3 and 5 buttons at the same time in case the switch in the headphone jack at the rear of the console is dirty, making it THINK that a pair of headphones is plugged in, and still nothing.
So the power amp is obviously not running, and I can't get it to turn on.
Perhaps a fuse has blown that feeds just the PA, but I doubt that because you can occasionally get a little bit of a pop out of it.
I did see one post in a thread that said something to the effect that the PA was "smart" and somehow measures the applied load on each channel and if one of the speakers (or the wiring to it) appears to be presenting too low of an impedance, it'll shut the whole amp down.
So my thinking now is that perhaps one of the speakers (or its wiring) is shorted, causing the PA to protect itself and shut down.
But I'm not sure if the PA in this system will be behind the dreaded right rear panel OR if it might be in the center console.
Before I start ripping the vehicle apart to find out what's were, does anyone have any sage advice about where I could easily get to, where I could actually ohm-out the four speakers and/or get at the amp?
Once I get it going, I will then have to choose between putting the original head in or putting in the new, cheesy (but MP3 compatible) one I bought.
But before I can have any sounds, I've got to get to the bottom of what's killing the amp.
This is my first post to this forum. So far, I've found a LOT of good ideas. Thanks, everyone!
