BillyBoy72
- November 13, 2017
- Belleville, NJ
- 1996 Explorer 4x4 V6 4.0
Ok, so here is the situation. I have a 1996 Explorer 4x4 Eddie Bauer 4.0 V6. The truck has never had a transmission issue and whenever I checked the fluid in the past it has always been just right. So I have never added or removed any fluid. Recently the truck sat for a year, I put it back on the road and made an initial 50 or so mile highway trip. There were no issues truck shifted fine. Next day went for a couple quick runs and after about 10 miles I was stopped at a light and when I went to go it was like the truck was in neutral. First thing I did was check the fluid level. The fluid was way over filled. So after talking to some people it was suggested that maybe there was a hole that was allowing coolant into the trans. So I disconnected the upper line running into the radiator with the intention of pumping some fluid out and have a look at it. When I started the truck nothing pumped out. So I switched to the lower line and again nothing pumped out. I noticed that the upper line did not leak any fluid when I disconnected it but the lower line did have fluid in it. So I was thinking that the trans was not overfilled, somehow all the ATF wound up in the bottom of the transmission. So thinking that there was a clogged line or filter or something. I dropped the pan and replaced the filter and gasket. The pan was nice and clean just that fine powder like shavings on the magnet. Old fluid is still pretty red and smells fine. I put 4 quarts in it and started the truck. It seems to still not be moving fluid through the trans. So that's where I'm at. Im thinking pump died maybe, but the only thing that's bothering me is all the fluid wound up in one place. If the pump died I'd think the fluid would still be evenly distributed. But if there was a clog then that may cause the fluid to be pumped into one place and stop there. So I'm not really sure where to go from here. Another question if the TC was pumped dry does it need to be primed for the pump to start working again? how would that be achieved? I read through some forums about a vacuum line to the top of the Trans, but Im not clear as to weather mine has that or not. I think from what I read that I have the 4R55E trans. Well thanks in advance. I'd like to work on it some Thursday, its my only day off.
