SA-Xplorer
- January 21, 2010
- Johannesburg
- '96 Sport 4.0L
First of all thanks to GIjoecam for the guide to 2nd gen 4x4 trouble shooting. My Sport has the same setup as the 96 4 door. I did the test with the following results.
1. Front up on blocks, front d/shaft moves freely, front wheels move ,do not cause counter motion on each other.
2. Start vehicle, set into 4wlo, driveshaft locked and wheels counter rotating.
So take it to a hump outside and test and driving forwards it seems to work fine.
THen I try the same thing in reverse and it does not work. Rear wheels spin, no front drive. I turn it around and try forward in 4wlo again and it works fine.
So I turn it around and try in reverse but this time I apply some park brake to slow rear wheell spin, and I get a clunk! THen the front axle seems to lock up and presto, I have drive to the front axle pushing up the hump while the back wheels are spinning. It works!
So what is the clunk?
Thanks! Ralph.
Thanks! Ralph.
