I just fixed my dash lights on my '97 XLT, only about half of them were working. I'm guessing your '96 would be the same? It was a real easy job. The bulb number is 194 (very common bulb) and there is a total of 6 bulbs. I replaced all 6 while I had it apart.
I also replaced the bulbs for the headlight switch and the fog light switch.
You will need a 7mm socket, 8mm socket, 1/4" drive ratchet, #2 phillips screwdriver, small/medium size regular screwdriver.
From memory... hopefully I'm not forgetting anything.
1. Remove the 2 screws in the radio/AC control bezel.
2. Pull the radio and bezel out some (as a unit) and move them slightly to the right.
3. Remove 2 screws from the plastic panel under the steering column (the one in front of your knees).
4. Remove the 2 screws from the hood release latch.
5. Grab this plastic panel near the top and pull it out toward you. There are a couple clips holding it at the top, be sure not to break them.
6. Remove the 6 screws from the metal panel that is behind the plastic panel you just removed.
7. Remove the 2 screws at the bottom of plastic part that goes around the gauges (these screws are behind the metal panel you removed).
8. Remove the 3 screws by the gauges.
9. Remove the gauge bezel, be careful not to break any of the plastic clips. You will need to unhook the connectors for the headlight switch and dimmer switch after you pull the bezel out just a bit.
10. Remove the 4 screws for the gauge cluster.
11. Tilt the top of the cluster in and the bottom out. There are two little clips that hold in your gear indicator. The clips move in different directions to release the indicator. Remove the indicator from the gauge cluster.
12. On mine there were 3 wiring connectors that plugged into the cluster. Unplug these connectors and remove the cluster.
13. Twist the bulb holders to remove them from the cluster. Pull the bulbs from the holders and replace the bulbs.
Now all my lights work
Be sure when you put the radio back in that you have it lined up right. There is a "track" that the radio goes on. I could do the job start-to-finish in about 20 minutes now that I see how it all goes together.
