BrowningA5
- February 17, 2011
- Salisbury, NC
- 97 Explorer
Hello. I have just replaced my automatic tranny with one from a salvage yard. It only has 2nd gear and is throwing a p0707 code. If I pull it down to 1st it will take off in first and then go to second but not go past second. I tried to change the range switch from the original tranny to see if it was bad. But the switch on the one I removed has a 8 pin connector and the tranny that I installed is a 12 pin connector. Also upon further inspecting, the new tranny has one extra sensor on the top rear of the case. Did they put two different trannys in this year? and if so are they interchangeable?
