koda2000
- September 2, 2011
- x
I'm having some strange problems on a '97 Explorer. I've never fiddled with anything older than a 2000 before and I'm experiencing some strange phenomenon...
1. the owners manual does not say how to program a new remote. I tried doing it the same way I've done it on newer trucks, and other than it requiring fewer key turns to make the locks cycle, it just ignores the new remote. the '97 remote looks slightly different than newer remotes I have and has 2 batteries. will a newer (2001) remote work on a '97? am I doing it wrong?
update: according to ebay, a remote from a 2000 Explorer is not compatible with the 1997.
2. the remote that the truck has will work sometimes and not others. there seems to be no rhyme or reason to this. it may work flawlessly 10 times in a row and then later it wont do anything. not even the panic button will work. if it was battery issue you'd think it would fail when using it repeatedly.
3. if I put the key in the door and turn it from lock to open a few times, I hear and feel the lock actuator cycle, but just a bit. not enough to push the button up/down. what's up with that?
4. every once in a while, the drivers side door button will not pop up to unlock the door. when this happens the key will not open the door either, nor will using the keypad, rear hatch or passenger door lock/unlock buttons. the other doors work normally. I think this may be a worn latch/lock linkage problem. I've lubed the latch/linkage with no improvement. any ideas?
