97 mountaineer 5.0 swap help | Ford Explorer Forums
Dtorres10312
Visalia
97 Explorer Eddie Bauer
Hello! I recently bought a 92 ford ranger rock crawler that the previous owner did the 5.0 swap; he got the donor motor from a 97 mountaineer. The previous owner literally ripped out the old ranger harness and replaced the entire harness with the mountaineer harness. Im wanting to clean up the wiring as there is a ton of wiring not being used. Im running a m5od r2 transmission, Atlas 2 transfer case. Its a dedicated rock crawler. I want the bare minimum wiring! Can anyone point me in the rite direction! Thank you!
Without the auto trans removed from the computer it will always whine about the auto trans being missing. Same for the transfer case, unless it was a 2wd previously.
