97 Mountaineer heater core removal. | Ford Explorer Forums
cincigreat
Cincinnati, Ohio
97 Mountaieer
trying to get to this heater core is giving fits! i got my dash off hvac is off, i cant get my heater core cover plate off. can anyone help?:mad:
welcome cinci
right now any info will help thanks
Are you saying the cover on the plenum won't come off after you remove the fasteners? Once you have the plenum out, that's all you do...remove any fasteners, split the case, and remove the core. It can be stuck pretty good. Clean the plenum while apart. Go to your wife's bathroom cabinet and get the alcohol she has there for whatever those ladies use that for. Use that to thoroughly clean any antifreeze in the plenum so there is no trace left to stink up your car. Reseal the core to the plenum. If your core doesn't come with a new seal, then you can go to the parts store, Ace, Lowes, etc and get some weatherstripping with adhesive on one side that will work. You want to seal the sides of the core so it's tight in the case and so no air can escape around the sides.
I'll give you one other bit of advice on ANY heater core installation. (for what it's worth) There are some real junk cores for sale out there. But a quality core!! I buy factory cores on jobs this difficult. Then I do one more thing. I take it to a radiator shop and have them pressurize it to 20 psi and check for leaks. Nothing will piss you off more than to go through all this work, only to have your new core dump antifreeze all over the passenger floor board.
What it is, i have my dash droped and i can see the cover but i can't get to the to all the bolts on the cover plate because the... I don't no what its called but the thing with the heater core inside of it i can't get it forward to remove all the bolts in it.
You know there are bolts on the engine side of the firewall that hold the plenum on.
Goto napa and buy a new blend door. Its around $10. Don't even think of NOT doing that. Should be cake with the plenum out.
Yes I have the 3 bolts and out from the engine side but i can't get off the blower its like its stuck. And in the inside i can't get to the bolts on top of the cover plate.
there is a bolt by the passenger right foot too that has to come out. Other than that it should release....
