derek54401
- March 8, 2009
- Verona, WI
- '97 mercury v8 5-speed
97 mountaineer 5.0
5-speed, AWD
the mountaineer has a horrible misfire which usually occurs after driving through a puddle or any rain covered road. It does not go away immediately after the vehicle has had time to dry out, the problem can persist for hours or even days.
I removed the wheel and used a spray bottle to wet the plug wires. when wet, there is a noticeable spark between several of the wires. Also, I can see a spark arcing from underneath the spark plug boot to the head.
The wires have been replaced twice to try and fix the problem, once with motorcraft wires and another time with napa belden wires.
plugs are autolite double platinum and are correctly gapped.
Any suggestions as to what could be causing this strange arcing and misfire?
Derek
5-speed, AWD
Derek
