97 Ranger tailgate blues. | Ford Explorer Forums
Snowboard
97' Ranger 4x4
I am trying to find out what is not working right in my tailgate assembly. I can't seem to find any diagrams of the internal workings of the tailgate. Does any one know where I should go to see any such diagrams? My Haynes manual doesn't even have one.
tailgate
the problem is that the handle is all wonky it seems like it is broken but it is still attached. There is a bunch of play in it. It isn't all tight
tailgate
No not yet I have to pull off my checker plate and then I have to grind off the rihno liner to get the plate off . the rihno guy didn't do the job very well . So that is why I was looking for some diagram of what's in there so I could at least wrap my head around what might be the problem.
....There is a long rod that goes from the handle to the latch....More than likely one of the plastic clips that holds the rod to either end broke...;)
...A dealer would have a diagram and the clip I believe is a dealer only item...;)
tailgate
Thanx for all the help I have the parts on order from ford. Just under $100cdn. Crazy. I couldn't find anything after market locally. Bummer.
...We have vendors on the bottom of the Forums page that could have helped find the parts you needed...Probably cheaper too..:dunno:
