the only thing i found in the haynes manual was the Brake Control Module "the brain of the ABS system..
if that is what you were looking for it is ::::::
On 1997 and later models, the control unit is mounted to the hydraulic control unit..
and the control unit is located on the driverside front corner of the engine compartment. it consist of a brake pressure control valve block, a pump motor and a hydraulic control reservoir with a fluid level indicator assembly
not a problem. if you need me to snap a pic of where it is located (since i dont have a scanner for my computer) just let me know i can get you a pic of the location.
