How to: - 98 5.0 AWD Auto to 5spd M5R2 and 4406 M | Page 16 | Ford Explorer Forums
How to: 98 5.0 AWD Auto to 5spd M5R2 and 4406 M
Prefix for threads which are instructional.
I know that this is an old thread, before anyone chops me up.
I just wanted to contribute something. I built a 95 Mustang using a 1996 Explorer PCM, its wiring harness and PCM - along with a t5 (manual). My car also developed the intermittent misfire. Disconnecting pin 58 for the VSS solved the problem and I still have a working speedometer.
Welcome, and thanks for the addition. I'm going to be swapping in a 99-04 wiring set into my 91 Lincoln, using the 97 Explorer PCM. The VSS should be workable in those early 96/97 computers, but there's still a lot to figure out.
It's cake, as long as you hav all the diagrams for the donor and recipient.
Hey Nick, do you think there would still be enough range of motion in the console hole to shift with a 2" body lift?
I have plenty of room and I used a 89 model transmission, with 2" body lift.
A 89 trans, 2" body, and a console? Awesome. I have a OBS trans as well and assumed I'd need a 97-98 top cover to make it work, so that saves me $100. My ex doesn't have a full console now but I wanted to add it if I can still shift.
Yup I'll try and post a pic of it all, I also went with a np205 tcase.
That would be awesome, thanks.
Pic for every gear position.
That looks great. Did you bend the shifter at all?
Sorry for cluttering up your thread Nick but this seems like the best place to gather this info.
Yeah I heated it up and bent it a bit but afterwards I wish I hadn't. It would have worked fine the way it was.
To add to the shifter conversation, here are different M5R2 shifters through the years.
Far left is from a 98 F150. The cross bolt is 90 degrees from OBS shifters. The middle is from a 9th gen F150. The far right is from I think an 8th generation F150. It has significantly more rearward bend.
I just used the one that came with the transmission.
My engine is in and I went to put the trans in and the shifter is so far forward it doesn't even make it through the hole. I'm not sure how you made it work 96ex5.0.
I found a high mileage 97-98 trans for $400 and a low mileage one for $450 so I'll probably get one of those, probably the low miles one.
Odd I know mine came from an 89 f150, I had to cut my hole I didn't use a pre cut plate that may be the difference.
It didn't even fall inside the removable panel. I would have to hack into the actual body.
I wonder if it worked for me do to body lift.
I picked up a 97-98 trans and it fits just like shown by others here - perfectly. As a perk my F150 front driveshaft should fit now, as well as my 4406 shift linkage without modification. They really took it to me though, that $428 transmission was $650 out the door after tax and core.
