98 5.0 limited po302 | Ford Explorer Forums
joker77_2005
bakerton,wv
98 5.0limited/2000 4.0xlt
i have a misfire that keeps comimg back on cylinder #2
new plugs and wires,new coils
the longer it idles the worst the misfire gets,once i get driving down the road the misfire goes away completely until i come to a stop and idle
sound like an injecter or has anybody else experienced this problem and found the answer
mike
Probably be best to check the compression.
•Faulty spark plug or wire
•Faulty coil (pack)
•Faulty oxygen sensor(s)
•Faulty fuel injector
•Burned exhaust valve
•Faulty catalytic converter(s)
•Running out of fuel
•Poor compression
•Defective computer
Compression great
Leak down 12-18% across board
New fuel pump n filter, pressure within spec
Swapped wires n plugs no change
New 02 sensors
No back pressure from cats
I bought a new set of injecters from ford,gonna try them
