FirstDueEngine
- February 25, 2011
- Austin, TX
- 98 EFI
I have a 98 EFI that has gotten progressively worse. Sometime in December it threw the usual both banks are running lean / rich. I followed the suggestions stating clean the MAF and IAC and cleared the code. No real symptoms returned. About 3 weeks ago it started having a rough idle and rough acceleration from about 1500-2000 RPMs. I replaced the plugs and fuel filter at that point thinking that would maybe cause some of the problems that it was having. The symptoms hadn't returned until a couple of days ago. Extremely rough idle and rough acceleration. It feels like it is missing, but the CEL had not come on indicating a misfire. I replaced the IAC this morning seeing if it would solve the problem. It has helped with the idle in park. It finally threw a code this aftenoon P0174. I went ahead and replaced the plug wires and cleared the computer, which didn't help either. Upon running the vehicle for a little bit I noticed what appeared to be smoke coming from near the intake manifold and coil pack.
It still runs extremely rough, any suggestions?
