'98 Explorer Hazard Flashers | Ford Explorer Forums
MGPguy
Atlanta, GA
98 Explorer
Help! My flashgers stopped working...but now when the flasher button is OFF my turn signals dont work...when the flasher button is ON the turn signals work but the flashers still dont work. I bought a new Plug-in flasher unit, but don't know where it is located on the vehicle. Help?
did you check if the wiring harness in the steering wheel is fully plugged in? the tab that holds it in broke off on mine about a year ago and gave me similar turning/flasher problems. just used a plastic zip tie to hold it in place.
The plug-in flasher is located behind the knee-board (the area in front of the driver's knees). To get to it, you have to remove the plastic "cover", then the metal plate behind it.
Remove the 4 torx bolts from the BOTTOM of the plastic knee-board cover.
There is one on each side, then a pair holding the hood release lever bracket on.
Remove the 6 or so bolts holding the metal knee board on.
The flasher unit will be on the left side of the metal cross-bar that the bottom of the knee board cover mounts to. It looks like (and is) a relay.
You can see it on the far left side of this image. This one is YELLOW, although yours may be BLUE.
