98 Ford explorer. Cranks but no start | Ford Explorer Forums
Lizzee858
Boerne tx
98 Ford explorer xlt
Engine light is on. Code is for camshaft position sensor. Just replaced it and now no spark. Replaced sensor, idle air control valve, and head gaskets
Did you get the electrical connector connected? If so, then check if you have any spark at the sparkplugs.
What code did you get? The camshaft position sensor does not control ignition; the crankshaft sensor does.
