lupin
- January 10, 2004
- London,Ontario
- 1998 explorer
Ok, I screwed up..after installing a remote starter myself I decided to finish by installing the PATS bypass module.I was not sure which connector I had to hook up the bypass to so I grabbed the first 4 wire connector I could find and unplugged it,then I put in my key and cranked the engine,it did not start and the theft light blinked rapidly so I figured GREAT I found the right connector.Well after finishing the install I tried to start it but now neither one of my keys works,it just cranks but does not start,the theft light keeps flashing .I unhooked everything I put on but still it wont start.
Did I fry the PATS system or does it just need to be reprogrammed?.Is there anything I can try that might help?.I tried unhooking the battery for 15 min. but no luck.
Has anyone ever had to have theirs reprogrammed,if so how much did it cost?..
