cla5675
- March 27, 2009
- Waynesville, OH
- 1998 Sport
Hey, all you A/C experts. I've bought a used low mileage '98 X Sport 4x4 with a 4.0 SOHC and I've had to do a few minor repairs with one last item to fix....the A/C. I put a gauge on the low pressure line to make sure I had refriegerent and the gauge is reading full. I then tried to by pass the switch with a jumper and still the compressor would not turn. I've checked the A/C fuses and relay in the primary fuse box, but is it possible there is another secondary fuse box somewhere that contains A/C relays which I may need to check? Also, I was considering running the compressor straight off the battery just to make sure it works. Is that okay to do or am I asking for trouble? Any info is greatly appreciated. Thanks!!
Troy.
Troy.
