98 XLT- fuse 26 and dome light issue | Ford Explorer Forums
lowellthomas
Lexington, KY
98 Explorer XLT
Hey everyone, this is my first post so let me know if I need to post this elsewhere.
I recently bought a very well maintained 98 XLT with 150,000 miles for $500. It’s been running great so far but I’m having a strange issue. I have no power windows, 4WD or interior lights. Upon replacing fuse 26 in the driver side fuse box I had power to all windows and i was able to switch between 4 LO and 4 HI. But as soon I as I toggle the dimmer switch on I lose both of them again. I have no dome lights so I’m thinking it could be a short in the switch or a relay issue. I check the fuse each time this happens and it doesn’t blow.
Any ideas of where I should start?
Thanks in advance
Thanks in advance
Do you have an overhead console? If so make sure no ones put wires up there to try to fix the foil crap. Also does your 4 wheel drive lights flash on your dash that means your 4WD fuse is bad.
I’ll check the over head console. And yes, the 4WD lights flash but go away once I get power to the windows.
Thanks in advance
Solved!
I swapped some of the relays around under the dash. The interior lamp and dimmer switch relays were both bad.
