Bruces expo
- January 19, 2005
- Middle GA
- 91 Mazda Navajo
Drove it home 60 miles with nothing major happened , it had a shutter while in drive or in park when i bought it for cheap , knowing it didnt run right , thinking i could fix it easily , well i decided to change plugs that helped the sutter and shake some , then changed the oil with mobil super - high mileage and a fram high mileage oil fiter , that helped with the shake and shutter a little more , then learned the bosch platinum plugs i bought werent the best to use , so i swapped them out with Autolite double platinum plugs , that made the shake and shutter even worse , i cleaned the iac valve and that started humming , so i took it out for a drive to see if it would maybe clear up if i drove it for a few mins , or maybe set a cel off , no luck , so i looked at it running in park in the dark and saw something red , took another look and it was my exhaust pipe :thumbdwn: my first catalytic converter was Cherry red aswell as the second and third , but not the forth , or my exhaust manifolds on either side , im wondering if my catalytic converter's are clogged up from so many miles and not being changed , any advice or suggestions are welcomed and appreciated , Thanks long time member Bruce
