ajb999
- May 6, 2020
- Couer D Alene, ID
- 1999 Ford Explorer XLT
I've got a 99 Explorer that has a short somewhere and trying to put a fuse in #26 blows the second it touches.
My rear defrost, rear wiper, and HUD?(thing above the rearview mirror) have never worked since I bought it. I believe the drivers side door has been replaced as all the wires running from it into the vehicle have non factory connectors and it's missing the rubber cover.
Occasionally the drivers side switch for the drivers window will not go up when pushing up then go down about an inch. I've traced it back to a spliced wire I just haven't had time to fix. I don't think this is part of my problem but just giving info.
So onto the new problem. I went to work, locked my vehicle and walked inside. About 5 minutes later people are yelling for me that my car has smoke coming out of it. Got in and smelled like burnt plastic/electrical but had to work. Go out on my break and windows not working. Start checking things out and no interior lights, running lights, 4x4 lights are flashing on dash. Check my fuses and 26 is blown. Also I think 29, the one for the radio. I work swing shift so don't get off until 11pm so know at the very least I have to get the running lights working. Run get some fuses, try to put one in 26 and arcs as putting in so just put it in to make sure since I've got extra and it blows. Also replaced 29. Driving back to work the radio stayed on but when I went to leave it was blown again. Left work early so I didn't get pulled over for no running lights. Also, the previous owner had replaced the stock 10a with a 30a so problems before.
So today I started pulling stuff off the dash and the front drivers side pillar and the entire way up the bunch of wires that go to the interior lights, vanity mirror, rear defrost and wiper have a burned wire that's melted into other wires at some point. I traced it as far as I could to the dash and it was melted almost everywhere I could see. In a hurry to get to work I cut it with enough slack so I could connect them all later. I know, super stupid but I was in a hurry for work. Still the fuse blows with key out, everything I can see to turn off I did including inside lights.
I tore the dash apart today trying to figure out where the bundle of wires go and after they enter the front drivers side corner of the dash I can't find them.
I'm not sure to go from here because this is my only transportation and I drive 30 mile one way for work. Also I'm not sure why the radio fuse started blowing alongside this. When they saw my car smoking one guy said it looked like it was coming from somewhere on the drivers side.
Sorry for the long post but just trying to give as much info as possible. Any help or suggestions will be greatly appreciated. I'm not the most knowledgeable car guy but have learned a lot working on them but when it comes to electrical systems it's probably my weakest area.
